What year is this 140?
tanman34
Just finished looking through parts diagrms from 85 to 92. 85 and 86 shows the usual looking anode number 96 on the diagram. But from 87 to 92 it does not show anything there. It is a big blank area on the diagram. And 96 is omitted from the list. So I think 87 to 90 is as close as I am going to get.
boobie
Look on the block for a core plug about the size of a quarter. If you find it take the numbers on it and call BRP customer service.
tanman34
Racerone you mentioned the linkage may need adjustment. I am pretty sure the gears are messed up, if they wernt they probally are now. It has did the grinding since I had it. At the ramp you can put it in reverse but you cant hardly tell your moving then you gas it a little it grinds. Does that sound like its shot?
My 120, I just quit using because that boat was shot. But it had reverse issues also, but that boat had seprate shift levers and gas levers. If you really pushed hard on the reverse lever you could get it in there but you had to hold it. Does that sound like an adjustment problem? How do you adjust the shift rod? Is it threaded on the foot end and you just screw it in and out to adjust? Hopefully I can salvage the 120 foot.
tanman34
boobie I looked they aren't there I think I see where they were but not sure.
