What's a CT scan involve?
CN Spots
Doc sez I need one. What am I in for? Is that the same as a cat scan? Most importantly, have I gotta wear one of them silly little get ups where your crack hangs out?:$
spots
Xcusme
Re: What's a CT scan involve?
Yup, Cat scan......
Painless unless you fall off the table.......
Wear sweat pants and sweat shirt.. (no metal objects) ....no need to expose your bidness , unless you want too , of course.
roscoe
Don't want to expose your crack, then just put the gown on backwards!
ZmOz
Yep...just lay down and wait while the machine takes a picture of you. Then you get to see a cool picture of your brain afterwards. 8)
CN Spots
Sounds like fun. Maybe I'll post 'em.
spots
Plainsman
Take an ipod or something to help you relax. Of course ask first if it's OK with them.
Pony
I remember when I had one a year and a half ago.......when they went to inject the dye in my blood, the IV exploded all over the inside of the machine and I was covered in a mixture of my blood, the IV, and the dye.8)
troypolla
I work in an office that has one of the 64slice CT scanners. You probably wont have enough time to listen to a song on an ipod. What are of the body will they be scanning?
CN Spots
"And expose your inadequacy?"
-read my thread on the mattresses.8)
They're scanning my noggin, sinus in partick'ler.
What's this I hear about an IV?
spots
Not sure if is this correct info but I believe they inject you with a radio active isotope in this procedure. Where is your thread on Mattresses, in the good news foerrimmmm;)
troypolla
The CT scanner is the part putting off the radioactivity. IF they will be using contrast, then they will start an IV in your arm if it is not a contrast CT then there will be no IV. IF IT IS A CONRTAST CT then be prepared to feel like you've peed your pants. If it is not a contras ctt then you will feel nothing and be done within minutes. The test that technostingray is talking about is either a PET scan (which detects cancer cells) or a Thallium Stress test (which does involve radioactive material being injected into your arm) or an MRI or MRA. Hope this helps clarify the situation.
CN Spots
Well then, I hope it's not a contrast CT. I got enough redioactive superpowers from my dentist.
spots
ZmOz
I didn't have to take or be injected with anything when they were checking my head for tumors. Just lay down, wait a couple minutes, and go home.
