What's the right boat prop help
RAP727
2011 Bayliner 185 flight series F18 4.3 Mercruiser I need to know the correct prop size and pitch. I bought the boat the prop that was on there was made to pull a wakeboard he was supposed to have given me the original prop but never did at 25 miles an hour I'm pushing 5000 RPMs
QBhoy
Holy moly. She’s way way under propped eh. Is the rpm limiter sounding an alarm on the dash ? Must have been some size of a man on the wakeboard that required that prop to pull him up !
I’d start with a 19” or a 21” and go from there. What’s on her now ? Must be like a 15” 5 blade or similar ? If your rpm and speed are accurate ?
I know a 1900 regal with a 4.3 mpi of a friends ran well propped with a 19” tempest plus on her alpha. Just around the 4800-4900 rpm wot at just a little over 50 gps. You don’t want too much pitch on these 4.3 MPi (if she is). They don’t have much grunt low down usually. Hope that helps.
Scott06
Sounds like it has a high five prop on it Given speed and rpms . Q has you steered correctly 19 or 21” pitch start with a black max or similar to get your bearings then can step up to something better if you like. Really depends on what you want to use the boat for
