What's your boat speed?
kfa4303
Banned
Re: What's your boat speed?
Kfa,
Thats a pretty cool setup you have there! How is the stability while on the casting deck? I had a 14' Alumacraft a long time ago and i always wanted to add a deck up front but never got around to it.
Thanks for the kind words. I love it. It's made it out of 2 sections of 3/4" non-PT, exterior grade plywood attached with SS screws to aluminum angle braces and 2 x 4 wooden pillars below deck for support. It's also tied into either side of the hull well above the water line. Overall, it's rock solid. It can easily support several people's weight, if need be, and is at just the right height for stepping onto from the dock (got lucky there). It's perfect for tossing the cast net, or fishing from too. My little nephew also loves to lay up there and look over the bow at the manatees and stuff as we idle down the rivers around here. The weight up front helps balance out the boat too. There's also another smaller deck below the main casting deck with foam below that for emergency flotation. In addition to having the casting deck itself, the whole unit forms a nice little storage locker to hold the anchor, PFDs, motor oil, pool noodles, junk, etc.... I've also made a couple small removable decks for myself and the passenger.They're also made from the same 3/4" plywood. They let me stand up nice and level while using the grab bar. About the only problem I've had with them is that they're painted with Rustoleum Professional Oil Grade High Gloss enamel, which is great stuff, but it can get slicker than snot when it's wet. I've already found some foam/anti slip mats I can put on them I just haven't gotten around to it yet. I think I'm gonna try to be clever (famous last words) and use velcro to attach the pads to the decks so that they can be removed when hosing out the boat at the end of the day. Here are some other shots to give you an idea of how she's laid out. Thanks again.
back rear 1.jpgfront floor 1-after-with cooler.jpgfloors and grab bar-2.jpgFront 6.jpg
barato2
i'd always wondered how those "restaurant kitchen" floor mats would work in a boat...the ones that look like a black rubber honeycomb. they're heavy enough that i don't think they'd slide around and i bet not horridly expensive, albeit hot in the sun.
kfa4303
Banned
Oh yeah, I've heard of lots of folks using them. The real restaurant ones are super tough and kinda heavy, but do come in red, brown and some other colors besides black (I worked in restaurants for years and years and dragged more than my fair share outback at the end of the night) I found some 24" x 24'' click together gray foam tiles from HF that I think I'm gonna use. They're cheap and practically weightless. Think flip-flop sole material. I may even get fancy and try to cut them the same shape as the decks themselves. Right now, I'm now trying to think of where I can find some industrial, preferably white, Velcro with which to attach them to the decks. I'm thinking a craft store, or something? It's not a must, but it would be kind of cool to be able to velcro them down to prevent them from blowing away, then rip 'em out at the end of the day when cleaning out the boat. We'll see. I have about a dozen little projects swirling around in my mind; jackplate/transom riser of some sort, fix the bunks on the trailer, reseal the LU to see if I can get rid of that pesky little leak once and for all, foam mats, etc.....You know how it goes. There's always something, but they're all fairly minor at this point and mostly cosmetic. Thanks to iboats, I've actually had more fun and time on the water in the boat ear this year than ever before, so I can't complain.
http://www.harborfreight.com/4-piece-anti-fatigue-foam-mat-set-94635.html (possible decking foam material)
liteboatr
1973 16' SS
Suzuki 4 stroke 40 hp
27 mph measured with speedo
starcrafter65
18' Holiday 130 Merc I/O - 34 MPH/GPS at 4500 with a 19P =- Definately could handle a 21 even a 23 - which would push you over 40 easily. The boat jumps onto plane with that 19 - I even have a 17 for skiing.
Both props I have are aluminum - would like to get a Stainless Prop someday - maybe a 20p.....
In the meabtime 34 is fine - don't want to go faster unless it is glass anyway!
gitmanone
1978 22' ss 235 evinrude 55 MPH at 5800 rpm great ride but a little too fast for the family
ckangaroo70
1979 Lowe Hustler 16ft
1979 Mercury Thunderbolt 50hp
10 5/8 X 13P aluminum prop with NO power trim
2 adults plus fishing gear and 8 gallons of fuel
28-35 MPH depending on water conditons. Good average is around 32 MPH GPS in light chop.
JD in Milwaukee
1979 22' Islander converted to a CC running a 120 hp white leg of death. A gps speed of 28 with me and pops on board. I was shocked.
tgp***
1966 Nassau 1967 650ss Mercury - 15 pitch prop
Paddle wheel sensor for FishEagle Mark340
WOT 32 to 34 mph - depending on water conditions. Its wild fast (for me any way) in that size of a boat! I wouldn't want to have to try and make turn at that speed in it.
Idle speed for trolling varies around 2 mph. A little high side. I would like it to be slower, but I'll live with it.
I going to start working on my other 67' 650 Merc soon. I did manage to find time to finally see if ran or not. Fired right up! Not pumping water though so I had to shut it down. The motor is in better shape than the one I'm running, . I found a guy that put new seals and water pump impeller/gaskets in my running 650 Merc for $85 last winter. I think I'll have him do this one too.
dkonrai
87 14 foot bayliner. 34mph per gps. 88 merc classic 50, but its a 45hp (?), 17pitch prop.
loaded, myself, and my two kids (21, 16) not little, two downriggers, bow mount trolling motor, trolling motor on the main motor, weights, 12 gallons of fuel, tackle, 6 rods, ice chest, life vests, and food too. took a while to get it on plane, but hit 33/34 wot. need a smaller pitch, need to try a 15 or 14.
dino
Stevens520
1975 Cheiftain Mark IV 25'
Mercruiser 888
29 MPH GPS
wilco
1976 Cruisers inc Macinac 227
OMC 190 HP ( 302 ford) stringer outdrive.
35 MPH at 4200 rpm
17 pitch SS omc cupped prop.
3.25 mpg at 26 mph loaded, with no trim on trim tabs. ( 3300 rpm )
Will try unloaded with 19 Pitch SS prop soon.
wilco
1977 Sea ray srv 21
HOT 350 I/O ( cam , heads, 10/1 comp/ al intake ) transom exhaust.
55 gps mph 5000+/- rpm ( had it 10 years ago dont remember for shure)
21 double cupped ss prop. Trimmed way out!
Hard to dock with this prop, idle has to be up with the cam, so not very slow boat speed at idle.
CheapboatKev
My 18 ft SS with the 19 inch prop on the 70 johnson got up to 60mph
On the tow home
Joeshow
1975 16' American.
1980 mercury 115 hp 19p prop.
43mph GPS, 3 adults and full tank of gas.
not racing
1982 HL180
1988 Johnson 88spl
39mph GPS just me 1/2 tankof gas and no matter what couldnt get it to 40
actually very pleased with 39 mph
halfmoa
Ensign
1972 Starcraft Super Sport, 1972 Johnson 65hp, 36mph on GPS.
Suprised me!
Bill3434
1970 Sportscrat C-Gull with 1977 Johnson 70hp 29.8 GPS with me and 12 gal of fuel. After my restore hope to be better than that I figured at a mininum 150lbs lighter.
tpenfield
Formula 330SS, Twin Mercruiser 7.4 LX MPI, 9,000 lbs, 160 gallon tank
54 mph GPS
