When to Change Fuel Filter/Water Separator ??
longstand
I have Twin Engine.. i remove both original Fuel Filter, and Route Both Engine Into 1 Fuel Filter/Water Separator..
How many Hours should i change the filter when i fill up the gas from Costco Quality Gas ???
This forum is the best..
Also my Filter is
Mercury Filter: 35-802893T
Mercury Bracket: 89876
JustJason
Re: When to Change Fuel Filter/Water Separator ??
You should have 1 filter per engine. If your running 2 engines through 1 filter your going to have a restriction. Restrictions mean the motors will both run lean. If they run lean enough they will blow.
After you hook both your filters back up. The correct answer is once a year or at the first sign of engine trouble.
longstand
Wow. i was thinking a whole a lot different from what you have said..
i was thinking. 1 less Filter means less Restriction..
Well i am going to install another Filter ASAP before i bring the boat to the OCEAN
thanks for the reply.. you probably just save my boat.. SLEEP better at night now
ALSO
I have Two Gasoline tank and i have a switch which tank to use.
This is how i should connect the two filter
Connect the Fuel Tank Hose to the First Filter.
Connect the First Filter OUT-Connection to the IN-of the second Filter.
just like that? will there be more restriction because i am using only One main Fuel tank HOSE that needs to provide two Fuel Filter? Please Educate me. because i guest i think Backward.
rodbolt
each engine must have its own dedicated filter.
if you have twin tanks its reccomended to run each engine on a seperate tank.
this prevents,or helps,from contaminating both engines in case of debris or water in a tank.
filters should be changed every fifty hours or 6 months whichever occurs first with todays fine gasolines.
do NOT run the filters in series.
JustJason
Just curious Rodbolt, is that a yamaha thing? I thought the Merc spec was 1 year or 200 hours? Was there a change I haven't heard about yet?
Fireman431
My Merc spec says 1 year or 100 hours. I'm considering adding an in-line pressure gauge to help in determining restrictions.
longstand
Ohh ok.. should using one Main Hose to support two Fuel Filter is a Bad Idea?
so i should just remove the Fuel Switch and use 1 tank per Engine? hmm
