Where are the shutoff valves?
Just bought a 2005 Larson 270 Cabio 5.7, and while I have almost every manual, there are things the manuals didn't cover. Mostly, where are the water shutoff valves? The person I bought from never tried to use those things, so he was no help.
The boat has a head with shower, and three faucets (head, galley, cockpit). When I turn on the water pump I hear it running, but nothing out of the faucets. I've put water in the tank, so I know it's not dry. There don't seem to be access panels anywhere
Any suggestions?
alldodge
Not going to find much of anything on the water system of a boat. Most don't have any valves from factory, any that are found have been installed by the prior owner.
Are you sure the pump works? Could be the pump needs replaced. The intake line going to the pump normally has some kind of a strainer, check to see if it's clogged. If the system froze due to lack of winterization you will need to replace some of it
Check the cabin bilge to see if water is leaking there.
tpenfield
I've owned 2 boats with water systems . . . no shut off valves. the only thing you might find with valves are the lines to/from the engine to the water heater (if it has one). If your pressure pump runs continuously, it may be broken or leaking, as AD stated.
Most boat water systems operate off a 45 psi pressure pump (Shurflo brand)
Well, the thing is that these valves are all referenced by the manuals. Intake valve for the toilet, for the air conditioner, for the the water tank to the pump. . .
flashback
You may have thru hull fittings for the AC and head but certainly not for the water heater.
Grub54891
Look under your sink in the head, or any nearby floor panels for a ball valve. Sometimes you have to look deep into your boat to find them. Ac unit usually has a valve near the circulation pump, normally in the engine room but I’ve seen some in silly places. All sink drains discharge overboard. As others have said look at your water tank for a screen type filter and make sure it’s not plugged up. From there the pump should be next in line and you can disconnect the output side and turn on the pump for a second and see if there is flow. Pictures of your setup help around here!
mr 88
The head may have a macerator pump , which will have a through hull valve , only open when discharging holding tank into the Ocean . AC will have the same set up , basically leave that on , all the time . It's there in case inlet hose lets go , shut it off . Odds are fresh water pump is bone dry and can't create a suction . Take the clear plastic top off it that holds the wire screen and put some water in it . No its not something that has to be done all the time . In your case , the PO never used it , for how many years ? Fresh water has a holding tank IN the boat , so no valves are needed .
Here's a pic of the pump. Up is up. It's mounted to an engine compartment bulkhead under the sink in the cockpit. Very difficult to reach, so I'm wondering: if I filled the freshwater tank and opened all the spighots, could I then prime the pump by pressurizing the line with the output from a shop vac?
alldodge
^^^agree self prime
The clear piece on the bottom is the filter.
You can get rebuild kits for them and they are fairly easy to do
mr 88
Supposed to be self priming , I've had one that wouldn't draw , was never used for a decade , and putting some water in the top got it to work.
Grub54891
Saw that fairly often around here. Supposedly self priming but depends on the outlet hose routing. A quick pull off the hose burped the air out of the pump and then it goes well.
chenlanlan
Any suggestions?
First, check near the water tank. Shutoff valves are often installed close by for easy access.
Also, look along the water lines that run from the tank to the faucets (head, galley, cockpit). They might be hidden behind panels or in compartments, even if the panels aren't obvious at first glance—sometimes you need to gently probe or check for small latches.
Another spot could be near the water pump itself. There might be a valve to control the water flow from the pump to the rest of the system.
mr 88
I have never seen a fresh water shut off valve , in-line or elsewhere . Boats I have worked on ,owned or looked at include , Hatteras ,Tiara , Boston Whaler , Pursuit , Luhrs , Wellcraft ,Stamas ,Sea Ray ,Chris Craft , Albermarle , Carolina Classic and even a Bayliner Motor Yacht . No reason for one ,its a self contained - closed system . As in , no water from outside the hull is used . So no shut off valves , turn the pump off ,water stops running .
Buster53
Just because you hear the pump running, doesn’t mean it works. I’ve had 2 boats that the pump crapped out on me and needed to be replaced. One wasn’t too bad, the other took at least 1-1/2, maybe even 2 hours to replace and was VERY difficult to access.
And as others said, you probably have an inline filter that needs to be checked first.
