where can i get.....?
ratking20
im looking for awlgrip or something similiar. i know ive heard that ameron, imron, sterling and interlux all have similiar products. im looking to save some money so where can i get a good price on this 2 part paint. it will be for my bowriders deck and part will be nonskid with griptex
emoney
Re: where can i get.....?
Where are you? I've found that it's usually cheaper to buy it locally to elminate shipping, but that's not always available. For me, I just go to the local West Marine armed with an online competitor's price and try and negotiate a discount through "price matching". Sometimes the manager takes pity on me and gives in.
However, if it's for the deck and has a lot of non-skid area, then I'd use a cheaper paint such as the marine stuff available at Lowe's. I'd only use the 2 part for areas like the hull where I wanted a nice shine.
Yacht Dr.
There are only two products that I know of that is in the True LP line.
1. Awlgrip ( not to be confused with Awlcraft2000 )
2. Sterling ( which is basically Awlgrip ).
I have personally seen Amazing results spraying both AG and Sterling. I have done some nonskid with griptex and Awlgrip roll on nonskid with durability results. ( No matter what paint system you go with..use the "griptex" anti-skid additives )
You cant Save money up front on the paint where these two are mentioned. But you save Paint and coverage/durability in these fine Marine paints.
There is Nothing better IMHO then AG or Sterling for nonskid ( aside from gelcoat which you might consider ).
Still.. there is something positive to be said about LP nonskid. You can roll it on with the correct hardener and have a lasting surface that is repairable.
Hope this helps some..
YD.
ratking20
what do u mean by LP? im in brooklyn new york. im not sure if i can find any awlgrip locally but im not sure. cheapest i found is about 176 a gallon for the color i wanted(kingston grey) and the catalyst is about the same.
