Where does this spring go???
Lrdrlker
I have a 1977 Johnson 70 hp outboard 3 cylinder. I recently removed the carbs for a good cleani g and when I was finished I ended up with a spare spring, which I assume goes on the middle carb because the linkage runs off the middle carb. I've looked on the schematic and I can't even find the damn thing! Pictured below. Possibly related...I now have a backfire coming out the exhaust when I increase the rpms in gear. Any ideas? Thank you in advance.👍👍20210618_072255.jpg
Vic.S
I have a 1977 Johnson 70 hp outboard 3 cylinder. I recently removed the carbs for a good cleani g and when I was finished I ended up with a spare spring, which I assume goes on the middle carb because the linkage runs off the middle carb. I've looked on the schematic and I can't even find the damn thing! Pictured below. Possibly related...I now have a backfire coming out the exhaust when I increase the rpms in gear. Any ideas? Thank you in advance.👍👍View attachment 343257
Throttle link spring, part number 0314807. #54 on the intake manifold parts diagram ??
This spring holds the CHOKE flappers OPEN at full throttle.------Keeps them from fluttering.
Lrdrlker
Thank you! I'll try and figure out which way it goes. Cheers
Lrdrlker
20210618_104951.jpgAny idea where the straight end anchors to the choke linkage
