Where to install temp sensor on Yamaha 175 v-max
Sorry the zinc not zone, I think they where talking about the andode bottom right on the port side under the starter
boscoe99
The existing thermostat cover is removed and replaced by one that has a port into which the temperature sender/sensor is installed.
Presumption being that you are referring to the use of a Yamaha standalone temperature gauge.
boscoe99
The model of your motor by the way is VF175XA. Very important. Write this down in your owner's manual.
