Which Evinrude 115 1999 injectors?
rustyscrew
Engine: Evinrude 115 ficht 1999 (E115FPXEEC)
I have my engine into a very reputable mechanic. I need new injectors. Every site online states that I need injectors 5000770 however the mechanic insists I need 5004477. I know these injectors had a lot of trouble, including fire hazard, anybody know why there is a discrepancy in the numbers?
Also, will 5000770 work?
thanks
multimech
Re: Which Evinrude 115 1999 injectors?
Your reputable mechanic probably has service bullitens which give the alternate number for a reason. The online sites probably don't have that information, simply the number given in the original parts breakdown.
boobie
Agree + 1 ...........
seahorse5
Chances are you do not have to buy new injectors. They can be rebuilt and recalibrated for a lot less money by dfitechnologies.com
Faztbullet
See if you can find S/B 2376R1
multimech
Might be just a superceded part number you guy found on his parts lookup and you did not.
rustyscrew
Thanks, turns out the injectors are completely obsolete and I called all over looking for them with no luck. I will look into the recommendation by Faztbullet though.
