Hi. purchased a newer boat. It is a 14' fiberglass boat v hull type with console. Hull weight is 260lbs. I have on it a 1994 Yamaha (i think it is a 1994). It is a 20 hp long shaft manual start and tilt. The plate on it states model 20 MLHS and the serial # 6L3 L 303125. It was imported for Japan to Canada. The prop on it need to be replaced as it has taken some damage. I need to know what would be the best fit
Here are my questions
1. First is my motor really a 94', I only find props for a 96-97
2. The prop I have now is a 9 7/8 X 10 1/2 3 blade. It is beat up and needs to be replaced. Not sure if it is the recommended prop
3. When I am in the boat I can get on plane and top out nice and flat at 22 MPH. I can travel 1-7 mph not on plane and then once on plane I have to maintain 15 mph or greater.
My wife and dogs get in the boat, Can't get onto plane at all and top out a 8 mph. My 15 hp evinrude on a 14' alumium still does about 12 mph with the same gang. and it only weight about 110 lbs less.
4. I understand that I may need to play with the trim, but any suggestion would help as I am for sure getting a new prop, just want the best fit for me.
Thanks in advance for any help.
Martin
Martin
