Re: Which sealant for screw holes, 4200, Boat Life Caulk or Liquid ?
Called a bunch of West Marine stores and took a pole. 6 said 4200 and 1 said Life caulk. So my boat is 4.2 x permanent since it is a 1968 Katama. will call Whalertown.
Read the data sheets for both and they're nearly identical products. So it's a Tastes Great - Less Filling argument.
You didn't say what sort of holes you are caulking. Just sealing otherwise good holes - caulk. Wollowed out holes, fill with epoxy and re-drill to proper size, then add a little caulk to the screw threads when you install it.
Caulk for small (< or = 1/8") gaps. The polyurethane variety lasts best - 4200 or Boat Life.
Caulk w/extra adhesive properties (5200) for bedding things you don't want to come loose until replacement time, like a port window frame.
Adhesive for connecting things a physical fastener like a screw isn't desirable for, like where you don't want to make a hole. Epoxy is the common choice.
Tensile (pull-apart) strength -
4200/BL = 300 psi
5200 = 450 psi
Epoxy = 400,000 psi
