White oil
robbyr1
Volvo Penta 3.0L GSM-A. I just replaced the flywheel and starter. After trying 2 different aftermarket starters that didn't work I finally got a good one and was able to start it. I replaced the flywheel because of this: http://forums.iboats.com/showthread.php?t=424468&p=2832036#post2832036
Anyways: after running it for a while, I turned it off and checked the dipstick. It was WHITE! Of course, I'm worried about a cracked block (would be about par for the course with my luck with this boat). My brother who was helping me said that it smelled like gas.
I did flood the engine a bunch of times trying to get it to start with the two faulty starters. Is it possible that a bunch of fuel got in there and had nowhere to go because it didn't start and ended up in the oil? Thanks!
Don S
Re: White oil
Water makes oil white and milky.
Gas makes oil thin and sell like gas but not milky or white.
robbyr1
Re: White oil
I was afraid you guys would say that. Thanks for the info. I guess it's new block time. Can you tell me what kinds of block I need? Do I have to get a "Volvo" one? From what I understand, most things on that motor are GM except marine parts, which are Volvo. Could I get a reman or boneyard block and use everything else I already have?
Re: White oil
Ayuh,... It's a Chevy motor, dressed as a Volvo...
robbyr1
Re: White oil
OK, thanks for the reply. I guess I can assume that there are plenty of Chevy motors in the boneyard. I am at my wit's end with this boat, along with an empty bank account. Is it advisable to get an old block from the boneyard? Any idea what I should expect to pay for a block? What is all involved in switching out blocks? Can a normal guy without too much mechanics ability with a manual figure it out? Thanks again for your help, guys.
Re: White oil
Ayuh,... The motor is used in Boats, Not cars...
Swappin' JUST the block, is well above most DIY'er's abilities...
What ya really need is a rebuilt Long Block...
