- Jul 23, 2011
- 51,729
Current colors were gel with a few diagonal stripes in vinyl. Since we spray Imron at work, going that route. Was going to go gel initially, however i really like the idea of spray and splash vs spray, sand, buff, polish then splash
Im doing all the prep, painter from work doing the spraying
First coat will be an adhesion promotor followed by a white primer. To not build up too thick, the red will be tapped off and sprayed. Then the boat retaped and spray the white. The black accent will be done last. Vinyl pin stripe will be used to define the line between colors
