Who's using a carport?
JaCrispy
I saw a few guys here are using car ports to keep their boat covered. Any opinions on these? Looking for low budget. Would make life a heck of alot easier.
haulnazz15
I'm not sure what you're asking. They work great if you need/want to provide covered storage relatively inexpensively. If you can swing it, having the optional corrugated side panels are also nice for blocking wind and rain, but the roof-only carports are still good options. I'm not sure there's a ton of differences in quality between most manufacturers, just make sure you secure it properly.
Frank Acampora
For inexpensive, you simply can not beat a tarp with a support down the center. Strap it down, or use bungee cords to hold it.
Use it one or two years and throw it out. Sure, it is a little more trouble to cover and uncover the boat for use but you did say low budget.
JaCrispy
I'm using a tarp now, it's not too bad but it would be nice if the weather man could get the forecast right once in a while. I've seen carports from under $100 to $1200. Just seeing who had one, pros/cons, etc.
Mel Taylor
I'm using a metal carport to cover my 16' Bluefin tinnie w/ tiller steered 30 horse Evinrude. I had some spare metal panels with which I covered the sides to within about three or four inches from the ground. both ends are open. I live in southern New Mexico where temps reach well over a hundred degrees in the summer and seldom dip much below freezing in the winter. I doesn't rain often but rainstorms can be fierce and even though the boat pretty much fills the carport from end to end, even a blowing rain doesn't cause enough water to hit the boat to even make a puddle in the floor. We usually don't get enough snow to worry about.
I think the carport itself cost somewhere between six and eight hundred dollars, NIB, several years ago and even had I had to buy the side panels the cost would still have been well within your budget constraints even today.
CONS: In the hot weather the metal sides and roof transmit enough heat to the boat that the aluminum parts of the boat get uncomfortably hot to the touch. At certain times of the year the sun shines fully on the outboard motor in the morning, so I try to keep a canvas cover on that to avoid UV and heat damage to the hood. I no longer have any soft vinyl seats in the boat, but if I did I would probably want to take them out and store them in some cooler place or at least cover them with something to insulate them from the heat inside the carport.
Other than those considerations the carport has been ideal for me and a far better solution than the vinyl cover I used to wrestle with every year.
Hope this helps.
JaCrispy
Thanks for the reply.
I think you have a "real" carport, with the extended roof panels, etc. I'm looking for something less permanent like this one from Walmart. Just for something to keep the rain/sun off the boat for the spring and summer. I have a warehouse I'll use to store the boat in the winter.
Ideally I would like to have something with a canvas top.
http://www.walmart.com/msharbor/ip/Caravan-Canopy-10x20-Carport/11007577
dingbat
it depends on your location. My neighbor keeps a car under one. Living on the coast, Its not if, it's when the winds come. He goes out, get the old one out of the neighbors tree, and buys new one.
Mel Taylor
I think you have a "real" carport, with the extended roof panels, etc. I'm looking for something less permanent like this one from Walmart. Just for something to keep the rain/sun off the boat for the spring and summer. I have a warehouse I'll use to store the boat in the winter./QUOTE]
Yes, mine is a metal carport. I misread your post and thought your budget cap was in the $1,200.00 dollar range, which would, of course be more than adequate for a metal one..
Sorry 'bout that
NYBo
I've used one for the last 5 years, and it had been in use sporadically for about 10 years previously for camping. One roof tarp has given up the ghost, but the second one is still in great shape. I take the tarp off in the winter and leave the frame up. I had a light duty setup from Harbor Freight, but an early, unexpected snow did in the frame.
Lager
Ive been thinking about the same thing because even tho I have a boat cover? Im constantly adjusting it to stop rain water from puddling on the cover and the hold down straps quick disconnects keep on breaking forcing me to use rubber tie downs.
So, I considered a car port, metal in design and ive found them big enough for about $600. I would still use a cover, but would a lot less concerned about cover tension to allow rain water run off. I looked at the link someone posted here about a Walmart car port? Thats not going to work for me at all. I can see a slight breeze just blowing that into my neighbors yard and a pile of twisted metal and the uprights only being just over 1 inch in diameter means now matter how I apply tie downs, its only going to fold up anyways.
The cheap car ports work and you can get 2 years out of one. For a boat I would cut the legs down so the port only just clears the boat then zip screw every joint. add 6 fence posts (green metal posts from home depo) beat them in about 16" deep next to the post then hose clamp them to the posts. After 2 years the canopy will be rotten, the post will be rusty and the rubber bungees will start to break.
My first one I didn't zip screw or add the posts. It turns out the canopy adds lift and once the frame lifts the posts fall out.
I would love a real carport but I live in a hurricane zone so this may sound strange but I can not find any company that will install one. The temp ones do well in 30-40mph storms but when the real storms head this way I use to remove the canopy and move the boat out of the frame.
MAC ATTACK
Getting ready to build a carport now ( lean to off of detached garage) so i can have lights/power etc. have been using a cover for several years, and last year went to a cover plus heavy duty tarp. The tarp when pulled tight does not allow any water to pool. Although my boat stays dry/shaded, it is a pain to cover and uncover every time, especially after night fishing for several hours and trying not to wake folks up when getting home
minuteman62-64
I've got something similar - $190 at Costco. Going into year 4 under the searing SoCal sun. Replacement fabric about $80, probably get next Spring.
HF also has a 10X20, can't remember the price.
loose rivet
I've been thinking about one of those 21x18' metal carports myself. The plan would be to pour two footings down each side and run a few courses of cement block on each side. Then mount the carport atop the block walls. It will both anchor it well and get it off the ground to help it last longer. A buddy has one to cover his two boats and loves it, he took two lengths of railroad track and bolted his to a length on each side, its not going anywhere.
Even if you just poured a four carboard tube form footings at each corner to bolt to, it should be plenty to hold it down in the wind.
vans
I need to do same, I like the tube footing idea
64osby
I use 5 gal buckets filled with rocks, rope is lashed to the upper corners.
MH Hawker
i just bought a new house and it came with a 14 x 24 carport, one on the metal frame ones, i need to move it to use it for boat storage but it will be nice. to not be out in the weather.
