Re: Why don't engine manufacturers advertise torque numbers
Well I don't want to completely contradict Silvertip's post as he is fairly correct about the relationship of torque to displacement. Lord knows we've had our spats, but the fact is that Peak Torque is really only valuable to a marine engine if the boat struggles to plane . . .
One way to prove this is to gradually bump your throttle up 100 RPM at a time and see if it will plane or not. Almost all boats will plane prior to having the throttle 100% mashed. If the throttle is not 100% mashed you are not at the max torque for that RPM, so basically with the test I am suggesting, with most boats, the only time you would be at max torque would be at WOT RPM. Again, the only place that you would have the throttle "wide open" and the only time you would be asking for peak torque for
that RPM is at max RPM and max speed . . . If your boat needs 100% throttle to get on plane, then you do utilize peak torque and an engine that had a little more peak torque would plane your boat easier . . . But even most 3.0s if applied properly don't require 100% throttle to get on plane.
This may be easier to understand if you look at these prop load curves from a Cummins diesel spec sheet:
The lower straighter lines are the prop load or demand curves. They represent what a typical prop (any prop) would require to spin faster, faster and faster . . . The top lines are what the engine is capable of. So it is easy to see that the big jump in torque at low RPM is not needed to turn the propeller . . . BUT what the load curve does not show is any rise in demand to get the hull up on plane. Yes, that point will dip into the available "reserve" power represented by the big white area between the two lines. However, again, if the throttle is not mashed 100% you are not on the top line. Period. The available max torque/power/fuel rate for that RPM is not required, so you don't go there. Now if you like to mash the throttle 100% because it feels good in the seat of your pants (I do), then more torque will make your pants feel better . . .
The fact is that the load required to spin the prop is almost linear, so you do not need the "hump" that steep torque rise (percentage of peak torque vs. torque at rated RPM) would get you. The application most common to trailer boats that likes high peak torque values is a deep-water start for a big slalom skier . . . The other biggee would be a heavy cruiser that needs all it's got to get up on plane. These are probably the only things that really
require a high torque value like a typical automotive engine other than the pants thing.
Oh, and the truck cam is primarily to help prevent water ingestion aka reversion . . .
and if geared and propped right the 7500 RPM engine would be great . . . it just wouldn't last as long. It would give you slower speeds at idle for trolling as the prop pitch could be significantly lower and still get good top speed with all of that available RPM . . .
