Re: Will 6HP be enough?
The river where I nornally run isn't real strong, but it is too much for a 4HP 24v MinnKota trolling motor, that barely keeps me moving against the current in the same boat. The current is slow enough there that you can't see it running by, but it's enough to tax the trolling motor. I ran a 15HP on my old 15" modified v hull jon boat there and it did good with about 22 mph as top speed with two people and lots of gear. I had a 9.9 before that and it did about 12 mph in that same boat. This boat is way smaller and way lighter, I now have an older 9.5 Evinrude that I tried and it does ok with me in it, but with two people and gear it does about 16 mph of so. I tried a 3HP motor, which came with that boat, and it moves the boat almost as well as the 9.5 on flat water with no current but the 9.5 does much better with stronger current. There is one section that I fish that has some pretty fast moving water, the 3HP slows to a crawl, but the 9.5 doesn't seen very affected buy it, the trolling motor is useless there.
