Will my 73 135hp lower unit fit on my 77 85hp Johnson?
taylor786
Someone said it would and someone said it wouldn't.
I would like your guess!
Thank you!
boobie
Re: Will my 73 135hp lower unit fit on my 77 85hp Johnson?
It should fit and shift okay. I don't know if the gear ratio is correct tho'. I'm sure I'll be corrected if I'm wrong.
jmanbaker1
Thank you!
ive tried that before, i tried installing the lower unit from a 1976 Johnson 135 onto a 1982 evinrude 115, and the reason it wont work is because the input shaft on the 135 foot is 7/8" diameter shaft size. the 115 has a 3/4" diameter input shaft. of course you cant take the shaft out of one foot and put in the other because the housings are different. they are two completely different pieces. i believe the 85hp motor would accept a 115hp foot, but not a 135hp foot. the best way to find out is to look up a water impeller for both motors and check the I.D. of each impeller.
McGR
As jman discovered, a '76 wont fit a '82. This is because OMC redesigned the lower units in the late 70's. However, '73 was the first of the hydro-mechanical LUs. This design was used on the OMC V4s until about '78 or so. I believe the '73 should work on a '77. To be sure look at the parts breakdowns at evinrude.com.
