redneck joe
- Mar 18, 2009
- 12,147
Read up on a couple old threads here and I'm a bit more confused than when I started.
Boat in sig line in question, bunks with glides on them which made it much easier but still too much. I crank, back in, crank, back in, etc. Truck is 3500 Cummins with 2 batteries.
Typical ramp is about 30%+ incline (Tim's Ford lake) other times about 10% (Guntersville). The latter is ok to load. Usually only have about 15' of pull onto the trailer. I'm a 'dunker' but not too much when loading especially on the steep inclines; the boat won't center properly.
Boat dry @ 4000 lbs, loaded probably not more than 5000 lbs (75 gallon fuel).
Why do some electric winches have a length limit? Example Master Lock Electric Trailer Winch - 2,000 lbs. Master Lock Winches 2953AT has an 18' limit yet has a 30' cable? And given the weight of my boat, and the fact that I have bunk glides should this sbe enough?
What is the advantage of buying a $175 hand winch versus what appears to be a workable power winch in the same dollar range? Dutton-Lainson Company - Since 1886 versus Black Bear Sporting Goods - Hunting, Archery, Fishing, Camping, Hiking, Boating, & more.. I don't mind winching, if it is effective but if I don't have to, why not?
Won't double up with a pulley will stay single line and even the 'slow' ones at 6' per minute would only be only 3-4 minutes max time and the Black Bear Sporting Goods - Hunting, Archery, Fishing, Camping, Hiking, Boating, & more. has a 6-8 minute run time so should be good.
Thought? Opinions?
Thought? Opinions?
