winter project
rocketman47
Folks
I have an 87' Ski Sanger 5.7 liter with an Alpha outdrive. Not sure how many hrs. on on it. I am considering a little engine performance tweeking by putting bigger cam kit in it, and bigger carb and manifold. Am I asking for trouble? What can I safely do to increase this engine's performance? Or should I just take the plunge and by a new 383 stroker crate motor?
Thanks! Randy
Re: winter project
Ayuh,... It depends on what you're starting with, 'n what cam you have in mind...
Generally speakin',... Big cams are a No-No...
rocketman47
Re: winter project
Currently the engine is bone stock. And as as big as I can safely go with the cam.. I would like the boat to have a little lope to it..
Randy
Re: winter project
Ayuh,... If it lopes,... It's WAY to Big...
