Winterising Mercruiser 4.3L
jak2108
Hi,
I want to winterise my mercruiser 4.3L 1990 model. I have taken out 1 drain plug on the exhaust elbows on each side and 1 on each side of the block at low level. I want to know if there are any more to take out. For some reason I thgought I read somewhere that there are 2 on each side of the block but i can only find 1.
Thanks
Re: Winterising Mercruiser 4.3L
Ayuh,... It's 2 on each side of the Motor,... 1 on the Block,+ 1 on the Manifold...
If you have P/Steering,.. Find the Cooler,+ pop 1 of the Big hoses off to drain it...
Also,..
Pop the Big Hose off the circulating Waterpump,...
It's hiding about another Quart or so,... Enough to do Damage...
JustJason
Whats funny is I have 1 OMC that I work on that's a 4.3 that only has 1 plug on the port side.
