Winterization- Drain Plug Locations, Etc.
KenleyF
not worth re-doing it now because it is fogged, main concern is if the engine runs OK in spring, due to possible fouling of sensors. So I'd leave it be for now, just be aware of this in spring.
Thank you, sir! Ill keep my fingers crossed in the Spring!!
Lou C
So when you re-start in the spring, let the engine burn off the fogging oil, it might smoke and run a little rough, let it run about 20 min on the water hose and then put in a new set of spark plugs and see how it runs then. I will often put an old set in for fogging then put the clean set back in after the spring start up. Plugs last longer that way.
