Re: winterize?
For carburated engines:<br /><br />1- add fuel stabilizer to fuel and run the engine to get stabilized fuel into the carburator.<br />2- decarb the engine if you have not done it in a while.<br />3- "fog" the engine, by spraying fogging oil into the running engine, per instructions on can.<br />4-Change oil in lower unit, this guarantees that there will be no water in the lower unit, which would freeze and crack the gearcase.<br />5- Remove the prop, clean the shaft and apply coating of grease, put prop back on, or take it to get reconditioned if needed.<br />6- Remove battery and store it in appropriate location, charge battery every 3-4 weeks.<br />7- Make sure boat has no water trapped in livewell or drain lines.
