This year I bought a Sea Ray Pachanga with a built 502. It has aftermarket EMI Thunder risers. While winterizing I drained them from the input hose but noticed that there is a plug at the base of each riser. EMI's site says these are so you can put the input wherever you want - do I need to pull all of these plugs to fully drain them?
To clarify - the input hose is the lowest point on the whole riser, just checking for anyone else who runs these to verify if the other plugs need to be pulled.
