ryno1234
- Dec 8, 2014
- 136
My boat is stored in boat storage facility indoors. The facility is not heated, however it is closed up from the hours of 6pm - 9am. Additionally, I live in Northern California in the valley where it rarely hits below freezing overnight.
My prior boat I never winterized and it was stored at the same facility. I never had an issue with it for the 11 years I owned it... (call it dumb luck?). To call out some specific things I never did prior to winter that I think *could* be important, I never:
I have a few questions:
I know this is a lot - thanks in advance!
- Added fuel stabilizer
- Drained the block / manifolds
- Fogged the engine
- Sprayed anti-corrosive on the exterior
- Put oil in the cylinders
- Added oil to the fuel filter and ran the engine until it died (why the hell is this suggested?)
- How important are these processes when the boat is stored like mine is? It's out of the elements, although may occasionally, but briefly hit sub-32 degree temps.
- I drained the block, but forgot to add the fuel stabilizer to the tank so I'll have to redo this process if I'm to work the fuel stabilizer through the fuel lines (although I can still add stabilizer to the tank, it just wouldn't be through the lines). Again, how important is this part? I've never had an issue starting the boat up the following year with the fuel in the tank.
- Related to above, I also forgot that I'd need to fog the engine before I drain all the water from it. How important is this?
- For the first time I also have some systems I've never had before and am very unfamiliar with: Septic, Potable water, Heater unit (not sure what this is called... it takes hot water from the engine and runs the potable water through some sort of heat exchanging lines to give hot water for showers, etc.) I haven't used any of these systems since buying the boat, largely because I'm still understanding how it all works. The septic system is "empty" (as close as you can get), the potable water is about half-full and I have no idea about the heat exchanger thing and how that might play into this.
