UncleWillie
- Oct 18, 2011
- 3,995
I like that idea of filling with antifreeze and then draining, how can I do this though, 5 gal bucket filled with a hose running to muffs, or does it need water pressure? Also what's this pink antifreeze you're referring to?
The bucket and hose method to the Muffs works just fine.
This method gets very BAD Reviews when done improperly.
It is imperative that the engine has been drained before flushing.
I place a plastic ball valve on the end of a short piece of garden hose.
Prime the hose and then close the valve to hold the prime while you attach it to the muffs.
Priming by mouth suction is doable. Propylene Glycol (PG) is a major ingredient in Nyquil and tastes about the same.
As long as you ingest less than a Pint, is harmless. It just tastes bad. (Unless you Like Nyquil!)
Place the bucket up high on the back of the boat and run the hose down to the muffs.
When ready to flush, open the valve and then start the engine. Idle speed Only!
The water pump's impeller will suck the Antifreeze into the engine at an impressive rate.
You will need about 6 gallons of Antifreeze.
A bucket will hold about 4 gallons reasonably.
Once the engine is started, dump the other 2 gallons into the bucket quickly.
Start with a cold engine as you will not get any cooling of the exhaust until about 5 gallons have been pumped in. (30-60 Seconds).
After draining, the old antifreeze can be filtered through an old T-Shirt and saved for use next year.
I have antifreeze going on its third use. I added a Gallon of -200 Last year. It will not even form slush at the -5F of my freezer.
PG (Pink) Antifreeze is available at a discount this time of year. A case of 6 gallons can be had for under $20.
Be wary of the antifreeze sold for under $3 a gallon. It is often Alcohol based. Be sure you get PG Antifreeze.
With alcohol Antifreeze, over time, the alcohol evaporates leaving only water. Bad.
With PG Antifreeze, the Water evaporates first, leaving a stronger mix of PG. Very Good!
Where are you located? See instruction below.
If you are expecting temperature well below 0F then the common -50F Antifreeze may not be sufficient.
It is avaliable in -50, -60 -100, and full strength -200F concentrations.
