winterizing
casy3175
This is my first Yahama, and I would like to find out what is needed to winterize
my outboard. I looked under the cover and there seems to be a connection to
attach a can of fogging spray. Is this correct?
And what other work should be done. Thanks
99yam40
Re: winterizing
which Yamaha 200?
they make 2 strokes and 4 and the year might say if it is carb or injected
Full modle # usually says a lot
Getting all the proper info is like pulling teeth sometimes, little by little it come out
casy3175
Re: winterizing
which Yamaha 200?
I'm sorry, hopefully this will clear it up. It is a 2003 Yahama 200hp-2 stroke outboard, fuel injected.
If you need the model number, I will have it over the weekend. Thanks again.
Shermanator31660
Re: winterizing
Definitely fuel stabilizer run through the system, I used to fog my carborated two stroke and I do know on the fuel injected snowmobile motors they have a built in "fog" button to do the same....Sherm
casy3175
Hi, I have a question that hopefully you can help. My 2003-200 hp Yamaha 2 stroke has been stalling out at high speed first then at lower speed. It starts up right after with no problem. It seems that the gas supply is being cut off. Would you have any suggestions. Thanks
99yam40
why are you posting this on an old thread on winterization
Just noticed you were the OP, and still have not given a model #?
