Wiring Tilt/Trim
Going to re post as this tilt/trim wiring problem is STILL unresolved!
I am now understanding ( I think) that the tilt trim on a Merc 200 HP black Max has TWO solenoids?
I have been getting responses that have pictures of TWO solenoids, however my motor appears to only have ONE?
I get a reply that my picture is of the starter solenoid? Apparently there are TWO tilt/trim solenoids somewhere by the number two cylinder, the size of quarters?
usskydvr
Re: Wiring Tilt/Trim
You don't happen to have the two solenoids mounted down by the trim pump, do you?
Chris1956
You might tell us the year of the motor. PTT units changed over the years
The serial number plate indicates 1986 Merc 200HP
The power head was replaced prior to me purchasing the boat so I am not positive as I don't see two solenoids, I see one!~
