wiring
oldman570
Re: wiring
If it is a 3 position switch as it looks like, it could be for the bilge pump, or other things that the PO had it the boat like raido, lights, running lights, or other addon items. You'll have to see where the wire goes and put it where you want to power that addon. Runnig lights here are required by law and have to work if stopped by the law or you get a ticket $75.00 here. Therefore they will need a switch. Best to check the laws covering boating there and wire the electrial ones in as needed. traikor wire works for most applications and is cheap at Walmart, or get a drop cord and it will do the job better and you don't have to buy a bunch of 10 foot rolls of wire. Mark each wire for what it powers at both ends and you'll know what it is for as you wire it an a year later. Use jumper cables made from a drop coard to test the old wire will tell wher the old wire goes as long as you are sure it dosen't go to the motor. Rewireing the motor and bypassing the plug will not hurt a thing as long as you have it insulated good where it goes thru the hole where the pulg was and you twisted and soldered thm and used the same gauge wire when doing so. I have done several older Mercs that way because the wires and plugs at the motor go bad. I have one now that I am doing that to for the same reason.
Have fun,
Oldman570
joe84
Re: wiring
the bilge pump is on a senzor and i have a switch for running lights so i assume its for any other addon
joe84
Re: wiring
i found stator on ebay can any one tell me what kind of cables i need and where the best place to get them length and all for throttle and shift cable cause i have n clue and wanna make sure i get the right ones
oldman570
Re: wiring
In order to get the correct shift and throtal cables for your setup you will need to take them lose at the motor, and mark each as to what it is, and measure them for length, and know just what control you have. A call to Iboats or other sellers of teleflex cables will get you the cables you need. Do not take the old ones lose from the control till you have the new cables so you can replace them as you take the old ones off.
Oldman570
joe84
Re: wiring
what is the purpose in a tach plug is it significant ?button.jpg and what is this?
joe84
Re: wiring
i dont see a trigger on this motor where it would serve a purpose is it suppose to have one i just seen something about a trigger is why im asking and one more thing is the throttle and shift cable the same design ?
oldman570
Re: wiring
Yes the cables are the same, and the button in your other post is a tilt, trim switch for a motor equiped with
Oldman570 one.
Chris1956
Re: wiring
Joe, You have a trigger inside your distributor housing. Sounds like you need a service manual....
Charlie61
Re: wiring
from what I see it' looks to be a trim switch may have been added later
joe84
Re: wiring
is this a twelve volt plug because i see niothing to step voltage up the reason im asking is because i've never seen a twelve volt plug like this12vplug.jpg12v plug back.jpg
joe84
Re: wiring
ok i have a new push to choke ignition and these wire colors i hard wired it so on the out side of motorplug where does the tan wire come in and whats its purpose and can i eliminate the tach plug? and please explain how to wire ignition switch up i think i know but i just wanna make sure i get it right 30.jpgignition.jpg
oldman570
Re: wiring
I belive the tan wire is the tach wire for the tach but not sure as I do not know just what controler you have. The tach plug is for the voltage to the gages in the dash and the tach sensor wire and should not be cut off. If the plug for the tach dose not have an other wire from it to the dash , an you plan on wireing things right, you will need to get that plugin harness to do the job. Your other option is to butcher it as the PO had. The 110 recitipal is proble for charging the battires and or a onboard charging system, you'll have to trace out the wires and see where they go. If they go to the battery the PO probley used a seperate batt. charger and used a 110 plug on the charger to charge the battries, along with using it to 12v. power any addon accessories not always used. Over the years I've seen some of the most ungoddly wireing jobs ever done by those that never had a clue. You reaily need to get a OMC manual for your motor as it will have most everything you'll need to know about the motor and wireing.
Oldman570
