OK I'm scratching my head at this and can't figure out whats wrong, kinda feel dumb posting this but I'm stuck.
I'm working on a '90 Evinrude 150, I oversized 5 bores to 010 over and one to 064 over.
I did the 010 over cylinders to 3.510 and the 064 to 3.564
The 010 over are using WSM pistons and the 064 a Wiseco, all brand new.
The 010 over pistons fit nicely, slide in and seem to have good amount of side to side movement. The 064 Wiseco will not fit, anything past 1/8" requires pressure. These test fitments were done without rings.
I measured things a million times, I have a bore gauge, micrometer and digital calipers. Measured the bore in every spot I could think of, from the very edge at the top to the very bottom in a bunch of position up and down and rotating. According to my bore gauge in no spot does it go under 5.564 and if anything it's slightly larger by a thou. The piston looks to measure 3.558 - 3.559
What could I be missing here?
