Won’t Start in the Water
spinbp5
Well here we go again…
I finally got the boat running and have been running it at least once a week. It’s been about 3 months or so and this week I decided to take the grandkids fishing in the boat. Well wouldn’t you know it… I put it in the water and all it did was drain my battery and my jump starter. I put it back on the trailer and brought it home and charged the battery and the jumpstart and with two turns of the key the boat started right up as it always has before putting it into the water.
is this really possible? Won’t run in the water but will run out of water? I almost find this hard to believe.
Here are my specs:
1994 Glastron
Mercruiser Alpha One
MCM 3.0 Litre/LX
Digital Electronic Ignition System
Engine# 0F268907
Transom# 0F316451
Drive# 0F249994
4 Cylinder
Displacement 181 CID
Engine Rotation LH
Scott06
Here are my specs:
1994 Glastron
MCM 3.0 Litre/LX
Engine# 0F268907
Transom# 0F316451
Drive# 0F249994
4 Cylinder
Engine Rotation LH
So when it was on the water were you missing fuel or spark?
think the water vs on the hose is just coincidence. Maybe loose connection at cannon plug ?
kenny nunez
Try starting the engine and warm it up at home before leaving for the lake.
This way you know it will start. I always started my boats up before heading to the launch.
nola mike
Blows my mind that people don't do this. I always assume my engine won't start LOL. My neighbor had her boat on the lift (brackish water) all winter. Wanted me to help her pull it. Short story, she didn't even try to start it before hooking up the trailer and heading to the ramp. Just assumed it would start right up (spoiler alert, it didn't...and the shifter cable was frozen)
ESGWheel
Master Chief Petty Officer
As long as your start up process is the same on the trailer as it is in the water, agree with Scott that it’s a coincidence.
The pre-start and run is a good idea but also be prepared to do some trouble shooting in the water. Here is what I suggest:
Without the grandkids – so no expectation to enjoy the day on the water – this is a ‘troubleshooting’ trip but with a spouse or friend go to launch the boat. Have the needed tools, like a multimeter, a way to check spark (an old sparkplug will work), a jumper wire with some alligator clips on it like this link (you can make one of these at home or buy them > they are a great troubleshooting tool), and a flashlight.
Now for the launching > I do not know your ramp / dock situation but clearly you do not want to be in the way of others while troubleshooting, so this must be thought out on how to do. Idea is to get the boat in the water and hope it is a no start. If no start, now the trouble shooting comes into play.
Start the trouble shooing process by using that jumper wire to connect battery to coil like you have done before. If it starts, great. Pull the jumper and try again, if it does not start, great as now we know what to go after. If it does restart (no jumper wire) this is also an indication of where to start but not as definitive. Let me explain:
From your previous thread back in Feb, dumped a lot of $$ into this boat to get a ‘new’ motor. Post that repair, you had a no start issue that was eventually traced back to a wiring issue at the ign. switch. I think you are still experiencing a wiring issue but of a different nature > an intermittent one. I.e., you have an electrical connection that becomes disconnected when bounced around. I think that trailering the boat to the water (or back home) bounces around the boat such that it is causing that connection to make or break.
Which leads me to my next statement: it is good it did not start with the grandkids. I know it was frustrating to expect a great day on the water with them but would have been much worse if you are out on the water and trying to get home and cannot start.
Which leads me to the next statement: please, let’s get this issue fixed before you go boating again. Even if you have 3 or 4 successful starts, I am concerned that the root issue will reappear at the most inappropriate time. And this can be dangerous.
So here is an alternative idea. Instead of a trip to the boat ramp for a troubleshooting trip, at home on the trailer try jiggling around wiring harnesses and connections in hopes of getting a no start condition.
Sorry for long post but I started thinking thru this situation more and more as I was typing. And I have some other ideas on how to troubleshoot on the trailer without draining down the battery by trying to constantly start but I will hold for now and see what you are thinking first…. Thx.
spinbp5
I’d never had an issue with this until now. I’ve always been able to take it out and it would start right on up. But you still have a good point.
spinbp5
I think you might be right because the day before I took it out it started right up. So I will check the electrical again. One thing is for certain and that is that the battery seems to be draining at a fast rate (3 or 4 turns of the key and battery is dead) and this is a new battery. I’ll take the time to go through all aspects of the wiring and hopefully come up with something. Thank you.
cyclops222
NEVER EVER release the boat from the trailer without starting it up. AND doing a quick 3 second WOT test run.
Screw the ramp bullies and their B S remarks. Been there 1 time with local police help.
Grub54891
How long are you charging the battery? Usually it takes a deep charge after being low.
As a side not my friend always put new batteries in his camper every spring as they wouldn't hold a charge. He left it at my place for a week once and just for giggles I charged them up for him. He asked me what i did to hos batteries and all I did was charge them. He said they kept things going for two weeks easily and before they would go dead in two days. He would charge them for an hour before he used it. I charged them for two days slowly.
If the battery is to low it won't create spark.
ESGWheel
Bill,
This new info changes everything. Let me explain. A fully charged and properly sized starting battery should last more than 3 or 4 start tries before dying unless (1) you are cranking the heck out of it each time like more than a few minutes (don’t do this BTW) (2) there is an excessive current draw when starting.
If excessive current draw, then the voltage of the battery could easily drop below what is needed to create a good spark and thus could be the cause of the no-start condition.
So, we need to change course and investigate this because as stated above this could be the root issue.
Before we do I ask that you take a minute and think about all the fun times you will have with the grandkids later this summer and in future years. Boating is a blast and a good bonding experience especially if you get them to help (with proper training), teach them seamanship and how to drive the boat.
So, take that minute and reflect on all those good times to come. I’ll wait….
Ok now need you to check on a few things and report back on some others. Here is the list
  • First check to see if any of your battery cables (both pos and neg) look as if they are burnt or any discoloration of the sheathing. Also evaluate the cleanliness of the connections. They need to be bright and shiny including under the neg cable where it bolts to the block. Please post findings.
  • If not a sealed battery check with water level and make sure its correct level. Edit: if the cells are covered by more then 1/8” or so, charge first then recheck level and fill to proper amount.
  • Disconnect the battery by pulling off the Neg cable and put the battery on a charger and change for at least 24 hrs… hopefully charger has a ‘charge status’ indicator and it shows fully charged after that 24 hrs but if not keep charging until it does.
  • Post the brand, group size, and CCA and Ah of this new battery.
  • I do not recall if you have a multimeter or not. If not, need to get one (link) along with some alligator type probes, like this link. Please let me know if you have these tools.
I know you will get this solved with the help of all the good folks here, so keep thinking about those grandkids. :cool:
cyclops222
Crappy engines kill good batteries.
Size / horse power of engine ? Battery size ? # 24 # 27 or a # 31 ?
spinbp5
Issue was gasket on carburetor leaking gas. Thank you.
spinbp5
Bill,
Issue was gasket on carburetor leaking gas. I fixed that issue and the boat now starts with just a flick of the key. I’m actually on the boat right now testing it out. It’s been over a year since the block was repaired in addition to the many other issues that have been resolved. This forum is by far the best and it’s simply because of guys like yourself that have helped me.
So, as I said I am on the boat testing it at lake success. Ive noticed that I have an issue with not having any speed in forward motion. I referred to the service manual in setting up the carburetor speed idle and the gas intake. All this basically does is sets up the carburetor speed idle which is one turn from the original carb setup in the book. I completely under why the boat needs to be in the water opposed to on land for corrections needed.
So right now I’m working on getting the boat to give me the speed I need to match with the rpm’s.
I hear the rpm’s going up but the boat won’t move accordingly.
ESGWheel
Solving the starting problem is great news! And how frustrating on the next issue. Keep thinking about those grandkids!
Is the 'not matching what you expect due to RPMs' the same for forward and reverse? If yes, it could be a spun hub for the prop or a bad coupler.
I am not familiar with your sterndrive if can even spin the hub. So try this with the boat on a trailer. Engine off and put in gear. Try to hand spin the prop and observe the prop nut while doing so. Does the prop make three or four tuns while the nut stays still? Then a hub and easier fix. If Nut and Prop are spinning in sync (but you can spin) then coupler. Here is a video showing that, link. Note have the drive in the almost down position for this. If the coupler, hold onto your hat, the motor needs to come out. Its like a clutch on a car (not the same but the same location, hence motor coming out). Let us know.
Grub54891
Yes, mark the prop with a dab of paint or a sharpie across the inner hub to the outer hub/blade area. When you put it in the water and try to go but it doesn’t, check those lines you put on the prop. They should still line up, if not it has slipped the hub.
as esgwheel said, sometimes his method works but I could never get the prop to slip myself that way.
