- Mar 8, 2009
- 43,993
This should be zero psi, it's before the pump. You need to place gauge between fuel pump and throttle bodytee from my fuel pressure kit between the in tank pump
Go to post 15 and click one the word "FUEL" it takes you to the TB and shows were it can be connected at
Don't run motor above 1500 on a hose. The hose can not supply enough water to keep from burning the impeller. Also not being under load will not provide the needed info
