Hello guys new to the forum. Picked up a 1990 Sunbird runabout has a Johnson V4 90hp motor.
Installed fresh plugs cleaned the carbs check compression and installed new plug wires.
Checked shift and throttle linkage.
Has great fuel pressure.
I have used water ears and she will run fantastic nice and responsive fires up idles fine.
I took it last weekend to the lake dropped it in. It took a while to fire up got to run it for about 15 mins It ran pretty smooth. Went back to dock to pick up a passenger and that when the trouble started.
Basically when I use the ears it works great. When I put it in the water and submerge the bottom end it will only idle. When I go to rev it in neutral it dies.
Could there be something in the lower unit or exhaust stalling it out. Something with the back pressure?
I would appreciate any help.
