JOHN_T_65202
- Nov 23, 2007
- 34
I have a 120 mercruiser on an Alpha One stern drive which was running ok when I winterized it this year. During the winter I put in new plugs, wires, points (gap set correctly), new oil & filter, stern drive water pump. Went to start it up, would crank but will not start. I have spark at all cylinders and fuel at the carb. I thought the plugs might be fouled with fogging oil so I took them out and cleaned them with ether. also cranked the engine while the plugs were out to clear the cylinders. still nothing. I always thought that if you had spark and fuel it should start at least. I'm stumped.
