Re: Work Begins Soon
Guys,
Doing the transom is not too difficult. I have mine about 98% removed.
It does take a bit of time. As I worked mine, I kept reminding myself how much money I was saving!
 I found the chainsaw method was too aggressive.  I used a wood boring bit with extensions to get most of it. A good shop-vac is a must. I also made some simple tools... Went to Home -Cheapo and picked up a 3' piece of 3/4" flat steel and a piece of 1/2" round steel.
I then welded an old 1" wood chisel (handle removed) to the end of the round stock, sharpened it up good... and away I went scrapping and chiseling down deep
The flat stock got a chisel blade ground on both ends, and then one end was bent in a vise to 90 degrees, about 4'' up. Makes a good hook tool for those stubborn pieces. A couple of tricks I learned were.........
1. I put depth marks on the tools. That way I knew I wouldn't go through the bottom
2. I ground the point off the wood boring bit when I was down about 19". It's a bit squirrely to control, but I sure didn't want to put a hole in her.
Lastly, be very careful of the through hull fittings. I gotta change all three of mine!
I still have to finish mine up this summer. I got involved in rebuilding an old 80hp Merc for her and it's taking allot longer than anticipated.
Let me know if I can help you in any other way
Regards, Ed
