Working under the back deck/splashwell
Watermann
Guys mainly think of 5200 as a sealer but it's a powerful adhesive as well. Repair looks good and strong from here.
theoldwizard1
Thanks Waterman ! I actually knocked the back off of a few of those pop rivets now that the 5200 is set.
I have been fighting with the port side "wing" that I cut off. It was still stuck behind the side interior panel. So while staring at that area in frustration. I noticed 2 screws imbibed in the side panel carpeting. What the heck, let see what happens when I take them out !
Low and behold, the little aft panel inside the rod locker pops off and you can now get your hand on the cut off wing ! Pulled it out, peeled the carpet off, scraped as much carpet glue as I could off, sand (60, 120, 180), clean (Brakleen), 5200, and more pop rivets. Now wait somewhere between 48 and 72 hours.
Maybe taking those side interior panels off is not as hard as it looks ! Just got to find all of the screws.
theoldwizard1
No Title
It's D O N E !!!
Seat base on casting deck was reinstalled with new SS machine screws, now that I can easily reach the under side
These first to pictures show the "wings" (minus their carpeting) that I have been taking about and how far they have slip under the interior sides of the boat.
fetch
fetch
The next 2 show the panel in place (yes I had to dis- assemble the wings from the panel and fit the in first), That is bare metal you see in the corners.
fetch
fetch
The last 2 pictures are the same as the previous 2 picture but from a higher angle to show that it was re-assembled using #10 oval head screws and trim/finish washer. Easy to find the screws tor removal !
fetch
fetch
theoldwizard1
The connections LOOKED CLEAN but the amount of current going to the gas gauge is so small (milliamps) that the least amount of corrosion would make it not function, I just separated the connection and re-connected them about a dozen time and it started working ! I saturated the little plastic shield with fluid film.
Grrr ! Splashed her in at the lake where we are staying and the fuel gauge is pegged a FULL (meaning it is not working). When I get home, I will remove the panel and SOLDER that damn connection !
