SaltInMyVeins
- May 1, 2013
- 24
Re: WOT Engine RPMs and Prop Pitch for Rebuilt 25 hp Evinrude
Apparently there r differing opinions on this. Local boat mechanics and others online r telling me the plate should be fully visible rt at the surface or just above. A cupped prop and proper trim will help eliminate ventilation during chop and turns. The prevailing wisdom seems to b to move motor up a notch at a time until it starts to vent, then move it down one notch.
The lower anticavitation plate must always run submerged and ride paralell to water level when boat is on plane, if exposed will experiment prop aireation at close turns or at choppy waters, but perfect for top end speed at flat straight course
