Re: WOT RPM only 4000; my next move?
Well, another update now that the boats back in the water. Surprisingly (and a bit dissappointing), I did not gain much at WOT with the changes to the boat (wet foam removal, hull cleaning). I am only getting about 3800 rpm and 37 mph at WOT with my 4-blade 18P piranha prop. Even assuming the Piranha isn't the best performing prop, I am still a long ways off the recommended RPM. My 19" 3-blade aluminum prop had maybe a tiny bit more at WOT, but close to the same.
I had the marina mechanic check out my engine and he said it's running fine. He adjusted something on the carb but very minor, he said. However, I am quite surprised a 200 HP engine can't spin a 19P prop on this boat. Yes, I do think I have a pretty heavy hull, maybe heavier than I think as I've never had the boat weighed. Also, who knows with a 22 yr. old engine.
At any rate, I need to get the RPM up so I just bought a used SS Rapture 17P prop on eBay, in excellent condition. The lake I have a slip in has very few danger areas for ruining props/outdrive so I'm not too worried about the SS blade hitting something and ruining the outdrive. I'll be able to test it out with the new SS prop in a week or two I hope.
What do you folks think I should see from the new prop?
