Woven Roving - Good for transom and stringers?
trendsetter240
This is a bit premature, but this winter I am looking at replacing the deck, transom and stringers in my boat. I came across a deal on a roll of woven roving. Basically half price.
Is woven roving good to use for transom and stringer replacement? .
Cheers
Woodonglass
Re: Woven Roving - Good for transom and stringers?
Yep you can use it. What weight is it? 18 oz would be good. I prefer 1708 Biax.
I'm just sayin...:D
ondarvr
For decades it was mat and roving and its held up well, the newer fabrics do work a little better (lighter for the same strength), but old school still works is fine.
Lots of boats are still made with just mat and roving
trendsetter240
Thanks guys, I'm going to check it out this week. Don't know the weight yet. So 18oz is what I'm looking for?
I'm not very experienced with glass work but I'm on the look out for deals on supplies for my upcoming project.
Cheers.
ondarvr
24oz is more common and is what's used the most to build boats.
Ayuh,... Roving is good strong stuff, but a tad Stiff for corners, 'n angles...
Woodonglass
Yeah, that's why I said 18 oz. 24 oz is really hard when it comes to corners. It would really have to be a GREAT deal for me to get away from using my trusty 1708 Biax
I'm just sayin...:D
swire
I'm currently redoing the stringers and floor on my boat. The stringers were covered in one layer of woven roving. Judging from how that turned out it isn't a good choice. It was delaminated from wood in spots, at the top of the stringers the fiberglass was all gone, the part that remained was not formed well to the stringers. Several corners raised up and the glass was actually out of the resin and full of holes to let water into the stringers. Maybe it was just poor craftsmanship on the boat but it convinced me that one layer of woven roving isn't going to cut it on stringers.
Woodonglass
Yeah, Like I said it does NOT do well making corners and you DO have to Really LAY ON the resin to ensure you get good saturation. Like I said the 1708 Biax is the BEST of both worlds and is WELL worth the extra cost you pay due to it's ease of use.
I'm just sayin...:D
trendsetter240
Great info, thanks guys. The guy sold it before I could get there so it's a moot point now.
Definitely good to know for the future should any more deals come across my plate. I'll at least have more knowledge and be able to make a decision to jump on a deal more quickly.
Cheers
ondarvr
You are correct in saying one layer of roving won't cut it.
If they only used one layer of roving they obviously did it incorrectly and then compounded it with poor workman ship.
When using polyester, mat should always be used as a first layer, and then between each layer of woven or stitched fabric, otherwise it will be more difficult to work with and be much more likely to fail.
There are a couple of reasons 24oz is used more than 18oz, in fact 18oz is used so little most shops don't have any on hand.
1. It will cost more per lb to make 18oz because the machine needs to do the same amount of work, but less total weight of product is made in the same amount of time. (glass is sold by the pound)
2. You should still use a layer of mat between each layer, so if you use 18oz the layup will be weaker for the same weight, or heavier to achieve the same strength, this also increases the cost.
As far as how easy each product is to work with, it can vary. Glass can be treated (coated) in many different ways and each manufacturer will have many different options for treatments, some can make it stiff and hard to work with, and others can make it soft and limp. The other thing that can affect it is age, sometimes when it gets old it can become very stiff and hard to conform to some shapes. So just because you find one type to be stiff and hard to work with, the next time you buy it it may work differently.
Also many of the retail sellers of glass buy it on price and availability, so just because they carry one brand right now, it can change tomorrow and work totally different.
