Having trouble overheating under 2500 rpm. the water pressure was showing 8-10 psi at wot. Replaced the water pump put new gaskets on the poppet valve but did not replace the spring in the poppet valve. Replaced the exhaust manifold gasket thinking a leak was causing the over heating problem. When flushing out the cooling system I noticed some water coming from the exaust. What could be the problem?
