y pipe....QU?ICK HELP
kewlkatdady
I have to loosen my y pipe as the guy that is "helping" me dropped a NUT down into it....
it has the 12 pts bolts...I have to borrow a 12 pt socket
what size are the bolts...
they look like 1/2 or close...
anyone know for sure off hand?
TIA
Re: y pipe....QU?ICK HELP
Ayuh,... The actual bolts are 5/16ths" or 3/8ths"...
The socket heads are 3/8ths" 12-point, or 7/16ths" 12-point...
Once ya pull it apart, you're gonna new a new o-ring gasket to put it back together with....
Don S
Pull the drive and reach it through the exhaust bellows.
Come to think of it, If you can reach the Y pipe bolts, that probably means the engine is out which in turn means the drive should already be off.
