This electric start engine has been running great no tell tail problems. Ran fine all the way out fishing. Re-started to return and engine started OK but cut off when put in gear 3 times. No prop restrictions. I used the idle advance lever on the shift to raise the RPM's, worked well went back to idle OK. In gear OK. When I started to run. . . No Power or very little all the way to full throttle, just a bit above idle speed. <br />The engine does not shake, spit sputter runs fine at slow or idle speed.<br />Got home connected the flush and started engine runs good. Put it in gear and ran the rpms up and it worked fine . . . back to the ramp for test and it's still doing the same under load. No power?
