Re: Yamaha 150 TKRD/cooling
I am in the same situation! However I noticed at the previous owners house that the motor took a while to pee. Out on the water peed like a race horse, now at my house, doesn't pee off my muffs. I am going to try some different muffs as I had too much leakage around them, so I need ones that fit better. My motor has a garden hose attachment for flushing the powerhead its located on the left side, kind of hidden up under the cowling. I flushed it that way and it took a long time for it to pee, which tells me there are miles of waterways through the motor. You can't run the motor while you are flushing the powerhead only, as there is no water down in the water pump area.
So before you tear into the motor try different muffs! or put it in a BIG bucket.
Let me know if this helps you.
(my motor is a 2004 150)
