joelisajer
- Dec 8, 2009
- 3
Hello,
Long time since I posted, but was hoping someone could help with this question. I have a loss of power but still starts and runs. Can't get above 2000 RPM. Took it back to the campsite and checked all sparkplugs. Found that coils 1-3-5 do not spark (right side). Swapped coils left to right and problem stays with the 1-3-5 cylinder bank (right side). Is there anything that would kill JUST the right bank of cylinders??
I metered out the ouput peak voltage, pulser and charge coils. Peak volts good on the only on left side(130volts). Charge coil tested within specs. Pulser coil I got .5 and .4 respectively per coil (manual calls for 2.0 or 3.0 cranking) - I don't understand the "load" versus "circuit" options though.
I can understand that I may need a pulser coil, but why only cylinders 1-3-5 that failed?? The pulser reads 330 ohms per circuit and not shorted to ground, seemingly the same for both coils. Position sensor also reads 210 ohms.
Any suggestions would be appreciated,
Thanks!
Thanks!
