Re: Yamaha 2005 f150 lower unit
go by any evinrude BRP dealer, buy the puller legs for the V4 V6 gearcase.
have them grind another 1/4 inch or so clearence on the tapered side.
they will know what ya mean. then get a standard harmonic balancer puller from sears or any auto parts store.
you will need both propshaft seals and the carrier oring at a minimum, taking an extra claw nut would be good. most the time I have to drill 3 holes in the original and take it out in pieces for saltwater use.
if you use the slide hammer attachment on the prop shaft then shift shaft removal will be required so add the shift shaft seal and housing oring to your parts list.
may as well take 2 drive shaft seals and the driveshaft bearing housing oring as well.
ALWAYS measure the depth of the original seals BEFORE removing unless you have the yamaha seal installer tools.
I cant wait to get back to Venezeula to do some work.
been almost 2 years.
