Yamaha 2008 50TLR Vibration
JustJason
Re: Yamaha 2008 50TLR Vibration
I wouldn't touch those carbs. In fact, its under warranty so I wouldn't touch anything. If you touch anything on the motor, and you are wrong and/or screw something up in the process then you take the chance of voiding the entire warranty. Then your up a creek without an outboard.
First you have to do some diagnosing. You need to see what's actually going on. Is it a low speed missfire? Is the missfire fuel or ignition or fuel system or compression related? Do you have good spark, what are the actual compression numbers? How exactly do the spark plugs look? What is the base timing set at? What should it be? Do you have a faulty coolant temp sensor/and or wiring that's locking back the timing
in the YMIS system and keeping the timing way to low. Do you have a fault in the primestart system? Is the primestart manual override lever in the wrong position?
Is it a combination of more than 1 problem?
Was this motor ever under water?
There are alot of variables my friend, to many. Think about what the motor is doing. If the issue was carb related then it either won't idle, idle to high or to low, consistantly hunt up and down for and idle, slight bog on acceleration, but it's not going to cause the motor to shake that bad. It may cause a stutter, but nothing that violent.
Timing on the other hand.... if that's incorrect then the motor will dance like a drunken redneck... all over the place. And if you have a combination of ignition and fuel issues... that redneck will try to breakdance to country music.
Take it slow, do some diagnosing. But just take rodbolts advice and call Yamaha and find a dealer with an experienced master tech. I fix these things all day long but if it was my motor under warranty I wouldn't touch it. Why should I? Somebody else gets paid to do it. And I don't work for free.
JustJason
PS.... What CD Manual you have there??? Is it the Yam manual in PDF format by chance?? :)
Don S
Found nothing out of the ordinary on that motor. I would suggest you sync the carb linkage before you start taking adjusting screw plugs out.
SKYCRANE
Ok gents, new scoop. Just had rotator cuff surgery so had time to locate a dealer with a master Yamaha mech. Took it in and they backed the boat into a tank so I could show them all the problems I was having with the motor.
So after a quick trip to Academy Sports they called and said the boat was ready. Get back to the shop and they ran the motor for me again. Come to find out that the motor was never set up from the factory, the timing was off and all three carbs were out of sync. It took most of the vibe problem I was having out. Now just need to get healed up so I can take it on the water and test it out in open water instead of a tank. Of course set up is not covered under warranty but the cost (Less than $100) to get the motor right was worth it. But like I said will know more when I can get it back in the water.
Thanks for all the info from all of you. Will post a update after I hit the water again.
rodbolt
thats why you paid for the first PDI to be done.
no PDI is not a warrenty issue but fax your original PDI sheet and the repair to Yamaha.
sometimes they pay visits to dealerships.
its maddening but happens,gundecked PDI sheets.
if the Pre delivery inspection is done line by line its very rare to have an issue.
