condog_aus
- Jan 1, 2005
- 5
Hi my mates got a 3yo Yamaha 25hp 2 stroke outboard. It starts and runs perfectly at idle and mid throttle. It also runs perfectly at full throttle but after its primed fuel supply is exhausted it goes off song but still runs at idle even if the throttle is held full open. If however you give the primer pump a squeeze it instantly comes back to perfect running at high speed. <br /> <br />We have tried a whole new fuel line and pump so its not an air leak in that section. The diaphragm was replaced by a yamaha service agent and that didnt fix it. Its like the engine lacks the suction to draw the fuel up by itself. If you pump the primer pump it will run perfectly until the fuel pressure is gone. Suggestions please. <br /> <br />All the filters were also replaced by the agent and the plugs. <br /> <br />Thanks in advance.
