Re: Yamaha 3.1 225 EFI Fuel Pumps_why are the diaphragms going out
Symptoms: You'll lose top end briefly, then you can back off on the throttle and hit it and it will come back. I'll don't use full throttle much, but when I need it I want it there. I'll usually lose 4-500 rpms when a pump is bad and then get it back if I back off and punch it.
Off the water if you loosen the pump(s) from the block and pump the fuel bulb fuel will come out of the back of the pump. This is a closed fuel system so there should be no leakage from the pumps. Keep running a pump like this and your powerhead will eventually crater.
I thought the same thing the first time I bought pumps; that they must be old. This last time I purchased them from a large on-line retailer that does lots of business. Doubt they could be old.
