Yamaha 60 autolube
cat990
60ffto,6H2 L 6H304 Y-1 this is all the numbers on the engine, my engine runs perfect at full throttle when cold, but after only about 250yds it dies down and if you try'an open the throttle it sounds like its being strangled and stinks in fuel, if i tilt the engine up it will rev out but no sooner i drop it again it dies again but keeps running just smells very rich, if i stop and allow the engine to go cold its perfect again, the carbs have been stripped and clean by a marine engineer its like the choke is staying on, please help
rodbolt
Re: Yamaha 60 autolube
sounds like its either flooding, usually due to defective needle/seat/float or the fuel pump diaphram has a hole in it and will pump fuel directly into the crankcase.
cat990
hi thank you i will try the diaphram first has the carbs where rebuilt, and was running fine on the other boat, i thought i might have wired it wrongly will let you know result.<br /> Cheers
cat990
if it is the diaphram how come it dos'nt do it when its cold, only when hot
cat990
Hi again i have checked the diaphrams on the fuel intake and there was a lot of like vasaline in it all in around the little flap inside would this of caused the problem as i can't get the boat out yet to test it
