yamaha 60 Hp TLRD 2005, pulled the power head and shift rod came out
astampfel
I thought I released the shift rod when I removed the cotter pin from a cam, but I have the power head up about an inch and the shift rod came with it. I see that there is a very small cotter pin directly below the power head that is tough to get to and is very small, so I'm a little hesitant to remove it. Any ideas on what to do? Did I mess up my lower unit?
Thanks,
Andrew
Capt Ken
Re: yamaha 60 Hp TLRD 2005, pulled the power head and shift rod came out
You need to unbolt the bracket on the side of the block. But no damage was done. It slides in and out.
astampfel
Thanks Capt Ken. I did unbolt the bracket and it worked! I still can't get the shift rod to align, but I'll keep trying. I guess if I get it in correctly, I should be able to shift manually and see which way the prop/drive shaft turns when I turn the driveshaft/prop?
astampfel
The darn rod wouldn't slide back in, so I took off the lower unit and cleaned the shift rod end. I assembled the lower unit and the shift rod went right in!!
